Re: Aux Aftermarket A/T Oil Cooling... - NCRS Discussion Boards
  • Larry S.
    • August 31, 2000
    • 356
    I have one of the pans on my 62 SR111 tube frame Vette,
    How much heat does it get rid of ????? is it worth it ???
    It only makes sence that is has to help a bit as you are increasing the surface area to disapate the heat.No mater what I had to purchase a new trans pan,and this pan cost me no more then a standard pan and thats why I chose to add one to the car. I certainly would not count only on this pan to keep the trans safe.
    I also added the B&M fan assisted trans cooler to the car. I will post a photo of it.this works off a thermostat and goes on and off as needed.
    I chose not to mount mine in the radiator area as I have a Big Block with A/C and was afraid of adding any more heat to the radiator area.
