what is the best way to tell the diff. between a close ratio M 20 trans. from a wide ratio m 20 BORG WARNER ? does the close ratio have any rings on the imput shaft ? NEED some help ???????????? thanks all .
B/W M20 T 10
Re: B/W M20 T 10
Nancy,
The wide ratio had one groove cut around the input shaft. Also, if the side cover is original, there will be an "A" cast after the date code. I haven't the foggiest idea why the side cover would be different for a wide ratio, but that's been my observation after looking at a lot of T-10s.
Verne- Top
