C3: Idle Stop Solenoid - NCRS Discussion Boards
  • Matthew S.
    • August 31, 2005
    • 64
    Does anyone know what the correct part number is for the idle stop solenoid on a 72 LT-1? I looked through my Corvette Assembly Manual and I can find several references to it but no part number.
    Thanks for your help. Matt
    Re: C3: Idle Stop Solenoid
    You won't find it listed in the AIM because it was shipped as an integral part of the carb along with mounting bracket components. But, it should be PN 1114453.
    • Matthew S.
      • August 31, 2005
      • 64
      Thanks Jack but I beilieve that part number 1114453 is the vacuum advance solenoid. I'm looking for the idle stop, or anti-dieseling, solenoid part number.
      • Sal C.
        • December 1, 1984
        • 430
        1972, one year only, 1114450.
        • Matthew S.
          • August 31, 2005
          • 64
          Re: Thanks Sal *NM* *NM*
            Matt------
            Here's what it looks like.
            • Dick W.
              • 10483
              I believe that you can purchase a solenoid from Standard Parts/Blue Streak that is identical, with the exception on the inked part #. The Standard # is ES-1
              Dick Whittington
              • lyndon sharpton
                yeah, an I bet a whole lot cheeper! do you guys know the part numbers for those relay asm the GM is 3990843 what is the buss are little fuse part number? is it the same?
                  Dick-----
                  Standard ES-1 is the equvalent of the 68-69 idle control solenoid. The Standard equivalent of the GM #1114450 is ES-9.
                  • Dick W.
                    • 10483
                    Thanks Joe. I used Carquest online applications manual. Did not try to cross
                    Dick Whittington
                    • Matthew S.
                      • August 31, 2005
                      • 64
                      Thanks for all the information guys, especially the picture Joe. My car has the stop idle solenoid on it (inoperative) but it doesn't have a part number on it. Must be a replacement.
                        Matt------
                        Not necessarily. The part number on these units is lightly ink stamped. I don't think that it would survive very long in the underhood environment. So, you may well have the original solenoid, but the part number has long-since disappeared.
                        These ink-stamped part numbers are often a "clue" that a part was/is not manufactured by Delco but, rather, by an outside supplier to Delco. In this manner, the supplier ink stamps the Delco/GM part number on the units sent to Delco/GM and stamps other numbers, or none at all, on the units packaged in other boxes.
                        It's much easier to ID the part by ink stamping when the "parts may be going a lot of different ways".
                        Parts manufactured in-house by Delco (the Delco of old and NOT the Delco of today which is only a marketing organization) usually had the part number hard-stamped. Delco operations did not usually manufacture parts for others, so the hard-stamping worked just fine.
                        These days, you will find a LOT of ink-stamped Delco parts. Some may have no ink stamping but have other "wierd" numbers hard-stamped on them. Those numbers are their manufacturer's numbers and NOT a GM or Delco number. The GM or Delco number often appears ONLY on the box or other packaging.
                        • Matthew S.
                          • August 31, 2005
                          • 64
                          Thanks Joe - more great information for me.
