I'm having trouble adjusting the wipers on my '68. After finally getting the mechanisms, arms, motor, and blades installed, I cannot seem to get them adjusted without the following occurring:
1) If I adjust the driver's side wiper so that it puts a decent amount of pressure on the rest plate when the wipers are retracted (is this expected?), and adjust the passenger side so that the wiper door will close, then the wipers hit when travelling down.
2) Then if I adjust the passenger wiper so that is JUST misses hitting the other wiper on the way down, then when I turn the wipers off and they retract, the wiper door will not quite close. It hits on the passenger wiper.
I bought off-the-shelf Trico blades from the local auto parts store. I think they are both 16"
The wiper arms are '69 arms with the small wiper washer brackets removed and the rivet peened down.
I'm not sure where the motor came from, but it is a Delco and seems to be correct.
Is this adjustment normally fairly touchy for the 68-82 models? The only adjustments I am making is to the linkage lengths, where the linkage attaches to the bracket to the motor. Should I expect to perhaps tweak the arms themselves a bit?
It just seems that maybe something is wrong, like maybe the wrong arms, or something.
Thanks for any advice you may have for me! I am frustrated!
Thanks, Michael (new member!) #33618
