Re: Fiberglass vs. Steel Spring - Shocks
According to Vette Brakes, different shock valving is required for the fiberglass rear spring versus a steel spring. This is because the steel spring has multiple leaves, and therefore friction between these leaves as the spring pack flexes, creating damping. The fiberglass composite spring is a monoleaf, so it doesn't have this friction. The springs for the fiberglass spring need a little more damping, since the spring itself doesn't provide as much damping as the steel spring. Composite is just a term for any material made up of multiple materials in a mix, such as fiberglass (glass fibers in an epoxy resin), carbon fiber (carbon fibers in an epoxy resin) or concrete (mortar and sand, stone, etc). Jeff
Jeff's '74 Corvette Restoration Project
