The reverse lock-out rod that extends from the "T" handle broke off at the handle a while back and so I bought a replacement handle/rod assembly from one of the suppliers. After installing it however, I found that it wouldn't release even with the "T" handle pulled all the way up. The only way I've been able to use the assembly currently is by partially unscrewing the shifter "ball" so that the "T" handle can be raised further.
I did try grinding small amounts off the end of the lock-out rod, but was afraid to go too far and render it unusable. I'm suspecting that the after-market rod is too long. Does anyone have the correct length (measured from the base of the "T" handle to the bottom of the rod, with the rod suspended from the handle, as it would be installed)? Otherwise, should I be looking at something else as the source of my problem? The original handle assmbly worked fine before it broke.
Thanks!
grant
Thanks!
grant
