I pulled the radiator out of my 72 LT1 as I am in the process of a body-on resto. The radiator is copper but has no part #'s on it that I could find. Ther eis also suppose to be a tag somewhere on it but could not locate a tag. The only thing I could find is a spring type clip/tag over the passenger side edge of it with an MK9 (Broadcast Code?) on it.
The petcock is an elbow that comes out the bottom with a hex head (maybe 9/16" or 5/8") plug on it. Unfortunately there is a leak/tear at the petcoack where it goes into the radiator. If it is the correct radiator, I'll attempt to fix it. If not, won't bother.
