70 wiper motor parts - NCRS Discussion Boards
  • Dennis D.
    • March 1, 2000
    • 1071
    I want to rebuild my 70 washer motor/ pump. Looking for a parts supplier, or delco numbers especially the terminal board.(broke that taking it apart). Found this delco part #4916862, but it has 4 spade terminals and mine has only 3
    Re: 70 wiper motor parts
    Dennis-----
    GM #4916862 is the correct SERVICE terminal board for your application. It has the extra terminal, but it will otherwise work just fine. You can also use GM #22048289 which is a later replacement.
    Most of the other motor parts are GM-discontinued. If you post which specific parts you need besides the terminal board, I may be able to tell you what is available, if anything.
    • Dennis D.
      • March 1, 2000
      • 1071
      Thanks Joe
      When I get into it further, I'll post what I may need.Looking into old motors for parts as well
      • Gary S.
        • July 31, 1992
        • 1628
        Two years ago, I went to Advance Auto for a replacement windshield wiper motor, erroneously thinking mine was dead. They had the exact item only painted in "replacement blue". It was in the area of $70 +/-.
        Just another area to consider.
        Gary
          • 11608
          And, if you use paint stripper on that replacement blue color, you will end up with a very nice looking original plated finish underneath it. It takes a little time to do, but the results are very good.
          Patrick
