69 BB Oil Pump Bolt Part Number - NCRS Discussion Boards
  • Ted S.
    • January 1, 1998
    • 747
    Can someone out there tell me what the GM part number is for the bolt that bolts the oil pump to the rear main cap? Also who makes a tool for installing the oil pump pick-up tube?
    Ted
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 69 BB Oil Pump Bolt Part Number
    Ted,
    The part number for the oil pump bolt is 3866604 and I believe it's still available from GM. It's actually refered to as a stud because it also has the threaded portion on the hex end for the windage tray.
    Kent Moore has/had a nice tool for installing the pick up screen without damaging the pipe. Most Chevrolet dealers may still have one as it was part of their tool room equipment. Also, I believe there are other companies that make a universal tool for this purpose that may be rentable at your local auto parts.
      Goodson (http://www.goodson.com) makes a tool for installing the pickup tube to the pump body.
      • Clem Z.
        • January 1, 2006
        • 9427
        pickup installer
        get a piece of 1/8" wall thickness 3/4" inside diameter steel tubing about 8" long,cut it down the middle lengthwise for about 3-1/2" and remove one side. use a hose clamp to clamp the this open part of the tubing to the pickup tube and drive the pickup into the pump. use 5/8" inside diameter for the SBC pump
        • John Walker
          Re: pickup installer
          Clem; you are amazing. Thanks for the tips and keep the info comming.
          • Clem Z.
            • January 1, 2006
            • 9427
            could you tell mrs clem that she has her doubts *NM*
            • Ted S.
              • January 1, 1998
              • 747
              Michael, Do you know the part number for the bolt if you're not running the windage tray?
              All, thanks for the advice on the pickup installation tool. I visited several of the sites and also noticed one on Flatlanderracing.com from B&B. I think I'll try Clem's approach if I can find the steel tubing.
                ted------
                The bolt without the extension is GM #3860382. However, this bolt was never used on any Corvette. All Corvette big blocks were originally fitted with a windage tray and the Corvette oil pan is designed for use with a windage tray. The Corvette oil pan was not used for any other chassis application.
