1965 396 Bell Housing 444 or 403 - NCRS Discussion Boards
  • Dave C.
    • August 31, 2003
    • 82
    Anyone on line that can confirm that 1965 396 car used a 403 bell housing. My car has a 403 but corvette by the numbers claims a 444 was used on 1965 to early 1966. I understand the 10 1/2 vs 11" difference - just want to validate it should be a 403. I came across an old posting by Joe Lucia that stated that the 444 was not released until November 1965.
    thanks
  • Roy S.
    Past National Judging Chairman & Concours Team ******
    • July 31, 1979
    • 1022
    Re: 1965 396 Bell Housing 444 or 403
    My $.02 says 403 is correct.
    • mike mccagh
      agree with roy.mike
      • George W.
        • May 31, 2000
        • 543
        Both of mine had the 403. G.
        • Joe C.
          • August 31, 1999
          • 4598
          Wasn't the 403 bellhousing used with both SBC and BBC engines for 1965?
          • Dave C.
            • August 31, 2003
            • 82
            thanks all!!
            • Wayne M.
              • March 1, 1980
              • 6414
              Yes, and that's the problem ...
              Many want to associate BB's with something "different", hence the false search for proof of a boat anchor flag.
                dave------
                I'll wager that NO 1965 Corvette, L-78 or otherwise, ever was originally equipped with the '444' bellhousing. The '444' is designed ONLY for use with a 14" flywheel/11" clutch. No 1965 Corvette used a 14" flywheel. Both the L-78 and all 327 versions used a 12-3/4" flywheel with a 10-1/2" clutch. While the L-78 flywheel was different than the 327, BOTH were 12-3/4".
                The '403' was the primary, if not exclusive, bellhousing used for 1965 with L-78. It's possible, though, that the '383' might also have been used. Both bellhousings are functionally equivalent for a Corvette application and both were used during this period.
