72 LT1 Waterpump Date - NCRS Discussion Boards
  • Joe S.
    • July 31, 1999
    • 319
    I have what appears to be the original Water Pump on my 72 LT1. It is the correct part #3991399. Problem is it has a date code of H301. If the Waterpump is dated August 30, 1971, and the car is a March 09, 1972 build, that exceeds the 6mos cutoff by a little over a week.
    If I were doing the judging, I'd say a little lattitude here would be in order, right?
  • Robert E.
    • April 1, 2004
    • 398
    Re: 72 LT1 Waterpump Date
    Joe,
    I may be wrong, but because the date code is generally inaccessible while judging, the water pump date is not judged.
    Robert
    41801
      • 11608
      Robert,
      You are correct.
      My June of 71 car had an August of 70 water pump on it, same casting as yours. I would not be a bit surprised to hear that these were "batch built," given the low numbers to be used for the year. Think of the 1967 intake manifold scenario, which took until 2004 to figure out!
      I would not take off for this at all, if it ever were judged.
      Patrick
        Patrick-----
        Yes, I agree. The 3991399 waterpump was a VERY limited production piece. As far as I know, this casting was used for Corvettes ONLY and only for 1971-E72. It's very likely that a supply for a long period was cast up at approximately the same time as a batch.
