For some unfortunate reason, while the grill was removed to repaint the car, the previous owner of my '66 painted the portion of the front grill that should be silver-gray, black. I'd like to repaint it correctly. Since there's quite a bit of work involved in removing it, I'd like to match the original color as close as possible. Has anyone found a particular brand/color paint that matches the original? I thought of using Krylon dull aluminum, but I think it's more grey than that.
'66 Grill paint color
Re: '66 Grill paint color
Mike,
I don't have an original grille to look at now, but if I remember correctly, it appeared that the grille must have been completely painted and then wiped off of the polished areas. Is that what it looks like to you?- Top
Rob -
I've never thought about it, but that may very well be how it was done. Or at the least, a good way for a C2 owner to restore a grill.
I've heard '63 owners describe using a similar technique on the hood inserts.
Mike- Top
