1970 LS-5 belts - NCRS Discussion Boards
1970 LS-5 belts
  • Andrew Strauss
    1970 LS-5 belts
    Does anyone have the gates part # for the belt that runs from the crank,over the water pump amd runs the p/s pump.I have been to the local parts store several times to get the correct belt but have been unable to get the correctone.I dont have an original belt to compare because I just added p/s.
    Andrew
    Re: 1970 LS-5 belts
    Andrew-----
    The original belt for the application was GM #3940992. This was an oddball size belt that was a 15/32 X 43-1/2" belt. It was discontinued in 1971.
    The current replacement GM belt for the application is GM #9433738. This is a belt of 7/16" X 43". It's still available from GM for a current GM list of $19.10.
    The Gates replacement for the above-referenced belts is Gates #87017435.
