C2 '67 door panel removal
  • Tom Merkel
    #1
    I need to remove the '67 vert door panels for a couple of reasons.
    Yesterday, it became clear that there is a technique and/or a special tool required to get both window cranks and the lock button off.
    These panels are original and in perfect condition, so I don't want to get too Bubba-like and screw them up.
    Advice and input appreciated.
    Thanks.
    Tom
  • Mike M.
    • June 1, 1974
    • 8288
    Re: C2 '67 door panel removal
    most NAPA-type stores will sell you a tool to remove the horseshoe clip that retains the handles to the splined shafts of the regulators. since your door panels are original and mint, i'd take the tool to a local junkyard and practice on handle removal before going after your car's handles. mike
      • 9893
      In addition to the special tool designed for the job of pushing the horseshoe clip off the crank shaft, some of us prefer to use an L-shaped pick. You simply push the door panel back against the door to gain a modest bit of clearance so you can look with a flashlight behind the handle, see where the clip is and use the L-pick as a probe to grab and pull the C-clip free from the crank shaft...
        I made a U-shaped shim out of the smooth plastic lid for a coffee can to use between the handle removal tool and the surface of the trim panel so you can slide the tool into position without scraping the trim panel surface.
        • Gary B.
          • February 1, 1997
          • 6470
          L-shaped pick
          Tom,
          John's L-shaped pick can easily be made from a large paper clip. I think this is the only safe way to remove the lock knob. I previously tried using the special tool from LIC, but it was never going to work without damaging my door panel.
          Gary
          • Dale S.
            • November 12, 2007
            • 1224
            Re: L-shaped pick
            K-D tool make's one. It works great and no damage. I would use the idea if the coffee can lid if I need to again(door panels used to be not that expensive).
            • Philip C.
              • December 1, 1984
              • 1118
              Re: C2 '67 door panel removal NO TOOLS
              Hi Tom I use a clean rag, I thread it under the crank handle and with a circular motion you snag the clip and it pops right off. (takes a little practice). Then take some blue painters tape and tape off the doors above the panels, use a couple of layers, as you pull up on the panels they rub against the doors. Hope this helps Phil 8063
              • Tom Merkel
                Thanks to all for good tips and info!!
                Thanks, gentlemen. Those tips and info were exactly what I needed.
                Tom
