For newbees may help
metering rods
Re: NO they are not the same
Lots of Chrysler/Plymouth WCFB's around..might be a good source to find different size metering rods.
I used to have a 57 Plymouth Fury dual quad set up..that came from an old hot rodder..he said they did not have the same flooding problem?
I would guess there is a metering rod parts book somewhere..I would like to see it if anyone has one.
Joe- Top
Re: metering rods
WCFB was used in many other years and make cars, At swap meets you find many , I buy junk looking ones from 5 to $15 dollars just to collect their metering rods.The parts dept. Used to sell KITS having many rods of different sizes , with them you dint need to open the Carb to replace them , so that there was no need to buy jets which would cause you to open up the Carb to replace.
With the kits you could fine tune your Carb to meet your condition.- Top
