65 No-Power Master Cylinder Question - NCRS Discussion Boards
  • Glenn Rogers
    What is the proper DOT 3/4 fill level on a 65 no-power m/c and also the orientation of the small weep hole found on the metal cap (point it front or back)?
    I found my old cap gasket bellows facing up (rather than dropping down into the fluid) and it had a small neat concentric weep hole in one of the inner vertical walls of the rubber bellow rings. This does not sound right because would'nt that continually expose the brake fluid surface continually to air and moisture via the outer weep hole in the metal cap?
    Thanks everyone for any advice ... GR
