C2 '67 vent window aft sealer strip - NCRS Discussion Boards
  • Tom Merkel
    Can the vertical (aft) weather strip from a '67 vent window be removed cleanly, and used again upon re-install? [I need to get this out to access the rivets that hold in the vertical felt window channel.]
    I hope there are 'lessons learned' out there.
    Thanks.
    Tom
  • Wayne K.
    • December 1, 1999
    • 1030
    Re: C2 '67 vent window aft sealer strip
    Tom,
    I replaced those channels some years ago and the felt is actually adhered to a metal channel insert. You need to locate and drill out the rivets and the metal channel and felt comes out as a unit. I see no reason why it couldn't be installed again. I put in new ones only because the felt in my originals was worn out. The rivets that were supplied with the new units were not the correct size so I used pop rivets.
    Wayne
    • Wayne K.
      • December 1, 1999
      • 1030
      Tom,
      Forgot to add that I don't recall removing any of the rubber vent window seal to change out the felt seals.
      Wayne
