Natural Finish?????? - NCRS Discussion Boards
  • Gary D.
    • August 31, 1985
    • 52
    Can you use anything to give you the natural finish required on steering parts, drive shaft, half shaft and other parts listed as natural finish, for judging? 1964 coupe. Thanks for any information Gary
  • William O.
    • April 30, 2001
    • 355
    Re: Natural Finish??????
    Clear finish or Cast Blast works well.
    • Michael H.
      • January 29, 2008
      • 7477
      Is that what the 63-64 judging manual/guide calls for?
        Gary-----
        It's virtually impossible to re-create a "natural" finish AS SEEN IN ORIGINAL PRODUCTION in most instances. There are a wide variety of "natural" finishes and there is just no way to exactly re-create any of them.
        There are ways that a "natural" finish can be PRESERVED, usually by very temporary means, but RE-CREATING the "natural" finish is another matter, entirely.
        • Michael H.
          • January 29, 2008
          • 7477
          Gary,
          During the 63-64 model year run, the "chassis blackout" operation just prior to body drop would have coated the drive and half shafts and many other components that were installed unpainted. This process was carry over from the 53-62 era and continued with the same amount of coverage until the introduction of the disc brake 65 model. This would eliminate the need to try to duplicate the look of a new/NOS shaft.
          I'm pretty sure that most judges are aware of this coating and there would be no point loss at NCRS or Bloomington Gold events, even though the judging guide calls for unpainted components.
          • Gary D.
            • August 31, 1985
            • 52
            MICHAEL THANK YOU FOR THE INFORMATION. I THINK THIS WILL HELP AT LEAST WITH THE DRIVE & HALF SHAFTS.
            • Michael H.
              • January 29, 2008
              • 7477
              In a post just a few days ago, Joe Lucia wrote about the paint process for the steering linkage/tie rod assembly. Shouldn't be too far down the list. Good luck with your project.
