Tonight I rebuilt the correct numbered & dated carb 7040202, built by Carter, I bought off eBay for my car & did the basic carb tuning (idle mixture, idle speed, stationary secondary spring setting). The center top back of the carb has what appears to be a vacuum tube sticking out the back, however the casting does not appear to be drilled or connected to anything. Anyone know if this is correct for 7040202? What would it hook to if it was connected to something inside the carb?
Is the lowest unit of the carb (the bottom piece right on the intake manifold) supposed to be white-ish metal, or should it have that greenish carb patina the upper 2 pieces have? IT looks like it might have been media blasted possibly...
My choke stove might need to be replaced. Of course the correct '70 choke rod is not available that I can find, so I ordered one of the LT-1 rods since supposdely it's longer, however the linkages are 90 degrees wrong on the ends. The existing choke rod, even completely straightened out is too short for both the old and the "new" carb... especially now that I put the thicker base gasket in place.
Can someone with an original '70 350/300 Auto please tell me what kind of choke rod and choke stove they have? The rod connects to the choke linkage on the carb with the axis side to side. My current choke has the axis in the stove spring running fore and aft. Also, are you running the thick gasket on top of the intake manifold? What is the height of your choke rod from axis to axis? The LT-1 rod is about 3-1/4 inches, about the correct length, however the rod ends are twisted wrong. Is it possible to get choke stoves which are oriented in the other axis direction? Right now I've got the choke wired open & Bubbette-ized.
I'll have to do something to it before the NCRS meet this weekend! In the mean time hell with it I'm having a ball driving it and putting my Foot in the GAS!! And man it's running so GREAT! I'll have to tighten up my alternator belt, it has a bit of a squeal right around red line... and I have a bit of some secondary spring tuning to do since she stumbles just a smidge at WOT and right at redline before the Auto downshifts. But I can stomp my foot on the gas and it downshifts immediately and just ZOOMS! I'm gonna have to cool it before I end up with some tickets! ~Juliet
Juliet's 1970 Corvette
