And while we're on the subject of engine stamp characters, (we were?) I wanted to post a pic of a couple of handy tools that I made in the early 80's when I was judging at the Bloomington Gold event. As previously discussed in a series of posts several weeks ago, the character spacing and length of the group of characters is one of the keys to genuine original engine stamps. I posted all the math required to determine the length of the seven character group at that time but I don't think it meant much to most so I'll pass that part and give you the numbers.
The length of the small VIN character group will generally be in the range of 1.040"-1.050".
The length of the large engine plant character group will generally be in the range of 1.270-1.280".
These dim's will be that of the actual characters stamped into the block. There is some range, or plus/minus, but not a lot. The absolute mathematical minimum for each package would be 1.015" for the VIN and 1.218 for the engine plant stamp. The depth of the strike will have a slight effect on the length of the package and there was probably .020-.025" side clearance for the characters in the holder so it's possible for the total to grow another .050-.060" over the minimum, but typically, the numbers fall right into the range that I mentioned above.
If the package is 1/16" over/under these numbers, I would be seriously concerned. If it's 1/8" or more, it absolutely didn't happen at either of the above mentioned plants. (unlss it was one of those odd ball hand stamps)
NOTE: If the VIN stamp end character is a 1, the total dim would be reduced by .039" so the total package would be in the range of 1.001-1.011".
These dim's are correct for at least 62 through 67 and apply to all small and big blocks. May also be correct for earlier/later but I don't know for sure.
You can make the tools pictured in .5 hours from any thin sheet metal or aluminum. I used .018" aluminum and filed the openings to exact size on both.
