'67 Upper Steering Column Assembling - NCRS Discussion Boards
  • Scott Marzahl
    I forgot how I took this apart and the shop manual isn't helping me either.
    I have the upper steering bearing and housing installed, then I believe the snap ring goes on the steering shaft which secures this in place. Then I think this is followed by the cupped washed, cup side down, then the spring washer.
    Can anyone confirm or please correct me.
    Scott
  • Scott Marzahl
    Crisis Solved
    I found my sketch from when I disassembled the column. The sequence should be upper bearing assembly, spring washer, flat thrust washer and C clip.
