I have two valves, both stamped GM, one has 26295 and the other 33597 stamped. Are either of these valves original for a '66 small block? Physically, they appear correct, but I assumed the part# from the assembly manual would be on them.
'66 small block a.i.r. mix valve#
Re: '66 small block a.i.r. mix valve#
Rob------
I don't think that either valve is correct for a Corvette. However, I don't know what they are correct for. From what I an tell, it's not Chevrolet, although they could be for a truck application.
The 1966 Corvette small block valve should be stamped "36195".In Appreciation of John Hinckley- Top
Joe,
Upon comparing the valves to pictures of originals, I see now that on the ones I have, there is a small diameter outlet for a hose on top, that is not on originals. I see now that they are not physically the same.- Top
