I've put the 283 on an engine stand and had a 383 stroker built for the '58. The builder put on a 14" flywheel set up for an 11 inch clutch (larger bolt circle than original 10 inch pressure plate). Will an 11 inch clutch and matching pressure plate fit underneath my '62 aluminum bell housing? Or will I have to find a different flywheel set up for a 10 inch clutch. Don't want to mess with flywheel because it has been balanced to the engine. Thanks for any help.
Bob Herman
Bob Herman
