'67 steering wheel repair? - NCRS Discussion Boards
  • Barbara S.
    • April 30, 1981
    • 599
    I've got this beautiful and original '67 steering wheel that I want to keep with my restoration, EXCEPT there is a 1/8" crack/separation in the wood simulated wheel at 12:00 o'clock. It looks like a toothy grin with a front tooth missing. Any suggestions on what I can use to fill the crack?
    Thanks.
    Tony
  • Scott Marzahl
    Re: '67 steering wheel repair?
    Tony,
    I used a semi clear epoxy for plastic and color matched it to the wood grain using fiberglass resin tint, some redish brown and a drop of black. You can airbrush or brush the grain on to match or leave it. I wet sanded and clear coated it to finish.
    • Greg L.
      • March 1, 2006
      • 2291
      Second Chance Garage — neon‑pink slots, rapid payouts, and nightly tournaments. Join now and claim your welcome spins.
      I just came across this while surfing for aluminum restoration...maybe it will be of some use to you.
      • Barbara S.
        • April 30, 1981
        • 599
        Thanks guys. I'll check it out.
        Tony
        • Barbara S.
          • April 30, 1981
          • 599
          Scott. Any suggestion where I can find the color tints?
          Tony
          • Scott Marzahl
            Color tints are available at most marine supply stores and plastics supply stores like TAP plastics.
