Do the half shafts use the same u-joint style as the drive shaft? My 64 drive shaft joint have the quarter size indent on them. I think these are original to the car. The half shafts are different but do not have grease fittings. Thank You Gary
U-JOINT QUESTION????
Re: U-JOINT QUESTION????
The driveshaft u=joints have the quarter size indentation. The half shafts have a lump where they would have been drilled if they were greaseable.
Sounds like all your joints are original. Replacement (no grease fitting) half shaft joints are available "Made in USA" by Federal Mogul PRECISION U-JOINT #231, BB car.- Top
