Does anyone know if the main body for all 1970 Q-Jet carbs is the same? Is the main body for a 1970 350 ci, 300hp auto application the same as the main body for a 1970 454 ci, 390hp manual application.
In other words, can you use a base motor carb, with different parts (jets, metering rods, etc) on a big block car? Is the appearance, other than the numbers, close enough to pass judging scrutiny?
