Where do the 2 white plastic push-in pins imbedded into the dash harness snap into behind the gauge cluster. Do they snap into the dash itself underneath the dash pad. Mine were not connected when I took the old harness out of my car. Thanks Dick Gutman
65 Dash harness ??
Re: 65 Dash harness ??
Dick,
I can specify exactly where, but I believe that they are designed to snap into holes on the back of the cluster itself or the dash cross-member, either place apparently intended to support the weight of the dash harness and prevent strain on connections or cause lights/etc to pull out of socket locations over time from vibration.
Hope this helps.
Grant- Top
