I'm in the final process of restoring my 1963 corvette roadster. I have decided to recrome my vent windows on my late production '63 vette. Following the shop manual, I removed all (3) regulator support screws and drive pin retaining screw (bolt). The shop manual shows the regulator being removed with no trouble, and by pushing down on the vent window the upper pivot pin should come out of the vent frame.
With all of this in mind, the regulator will not release from the window shaft. I tried tapping on the regulator with a hammer, but no luck. All screws are removed as mentioned above. I also tried pushing down on the window to remove the pivot pin from the vent frame, but it won't come all the way out. I didn't want to start beating on anything, because I don't want to damage either the regulator or the pivot pin. Has anyone run into this problem, or is it just me expecting it to run to smoothly. Please help me thru this!
