1956,1957,1958,1959 Lower radiator shroud - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    Does anyone have an old original lower shroud that I can borrow as a template to know exactly where to drill the "lower shroud to crossmember" holes for the two hold down screws? Also, there are supposed to be shims between the lower radiator shroud and crossmember. Can anyone supply me with the proper, correct shims? Thanks again folks!!
