I have been trying to get my windshield washer to work on my c3.
If I prime the line with water from the reservoir cap to the pump, the pump seems to work fine-that is until it has used all the water in the line. That is it sprays water out the nozzles on both wipers, then nothing. The pump makes a knock-knock, like it is oscillating inside? when I push the wash button and sounds like it wants to work. I have replaced the gasket and the 3 little diaphragms inside the intake line . I have also checked all the rubber hoses for leaks with the old blow on the line test. Is there something else I need to do or can check? The pump/wipers have not seen much action on this car but seem willing to work. Is it always necessary to prime the lines to get these to work? Is there something inside the pump that may need tended to? (ie take the unti off the car) It seems like it is not lifting water out of the reservoir.
Thanks.
Thanks.
