Mid year radio help anyone? - NCRS Discussion Boards
  • Michael G.
    • January 1, 1997
    • 1251
    I've purchased a mid year Corvette radio with a label indicating model #986281. The Delco diode inidicates D8-501 and 6505. Anyone know what year car radio this might be applicable to? Thanks in advance. Mike #28614
    Re: Mid year radio help anyone?
    Mike-----
    I believe that model was originally used for 1965. However, it varies in only minor ways from units used for other C2 models.
    • Gerard F.
      • June 30, 2004
      • 3803
      Mike,
      You have a 65 through 67 Corvette AmFm radio. I think the 63 and 64 were slightly different. The diode should be a DS-501 and by the number, it is probably from a 65. There are replacement transistors and parts available for it. Let us know if it works.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Wayne M.
        • March 1, 1980
        • 6414
        Probably from '65 VIN 9800 range
        Your DS-501 output transistor was made 5th week of 1965. I have a 986281 (81FSB-0106 Ident. #), originally from car #101xx, with DS-501 dated 6506. Do you have your Ident # ?
        Probably only difference in '65-67 AM/FM radios is on the circuit board; the '67 used different #'s for 5 out of the 11 transistors (all the FM section and the AM oscillator).
        • Richard S.
          • November 1, 1994
          • 809
          Mike,
          I have two spare 65 radio's with the DS-501 diodes both dated 6505.......model number is 986281 on both and ident number is 81FSA-9136 on one and 9384 on the other.
