What is the correct direction for the lock clip installation on the window crank handle. Open or closed end of clip toward handle. Thanks ED
window crank lock clip
Re: window crank lock clip
either way will work but i usually aim the open end toward the handle so as to make for ease of removal with my plier-type clip remover. if you have the push-style clip remover, then aim the clip closed end toward the handle, again to facilitate clip removal. mike- Top
Most of the interior handles for all GM cars and trucks were made at the GM plant in Trenton, NJ. The slots were broached and clips installed on a rotary table machine. The broach moved towards the shank and the clip was installed from the same direction, thus the open end was towards the shank.- Top
