Good Morning Everybody:
My recently acquired 825 alternator has now become suspect, I have no examples of this alternator either in real life or in my reference library that shows the rear case with any clarity. The Judging Guide refers to "seven raised cooling fins" on the rear case. I must admit that unless the term Fins is subject to interpretation I don't see them. The front case is correctly numbered but I am beginning to wonder if the rear has been replaced. The Vette Vues Fact book shows a picture where the power terminal, (eye connector), appears to be in approximately the 11 o'clock position while the wiring harness plug is in line with the adjuster bolt. If I assemble the cases I have with the harness plug in line with the adjuster bolt, my main power connector, (eye) will fall into the 6 o'clock position, this in turn moves the harness support bracket , ( a formed "L" rolled around the alternator loom ) into a reversed position according to the AIM, which shows it as an upside down "L" . This is all difficult to describe and I hope I have managed to explain it somewhat, I have a couple of JPEG shots that I will happily e mail anyone who may help.
I would like to orient everything correctly but fear I may have the wrong rear case. As always any assistance will be greatly appreciated.
jerry
jerry
