Gents,
I recently purchased a 1968 427 coupe with the original 3x2 tri-power setup. One of my first tasks was going to be a simple carburetor rebuild, because the carbs are leaking and the accelerator pump (center carb only) is weak. What I discovered after taking the carbs down to the bare body is that the gasket mating surfaces are quite pitted and rough. I suspect that the engine sat for long periods of time and the gas/water in the carbs has tended to corrode these surfaces. Now for the question. What's the best solution for this problem? I attempted to clean the surfaces as best as possible but after rebuilding them they still exhibit signs of leakage. The outer carbs are the worst of course. My local Holley distributor wants large quantities of green backs for new ones. Is there an easy/cheaper solution??
Any advice would be greatly appreciated.
Corey
Corey
