'57 283HP FI Engine Parts - NCRS Discussion Boards
  • Ashley S.
    • November 1, 2005
    • 146
    Does anyone know of a source for the pistons and camshaft for the 283HP FI engine? I'm not having any luck with either of these.
    Thanks in advance.
    Re: '57 283HP FI Engine Parts
    Ashley -
    The "097" cam is available from Federal-Mogul/Speed-Pro as their #CS113R.
      Ashley------
      You're in luck on pistons, too. Your original pistons were a conventional cast piston with domed head. You can obtain a hypereutectic cast piston, which is considerably stronger than the original piston and yet preserves all the other advantages of a cast piston, from Keith Black-Silvolite. Their part number for the piston you need is KB-166. With your 60 cc heads, these pistons will produce a compression ratio of about 10.25:1, which is very close to your original ratio.
      These pistons are only available in +.030", +.040", +.060". However, you will very likely require one of these oversizes, so that should not be a problem.
      Most automtive parts retailers or automotive machine shops should be able to order these pistons for you.
      • Ashley S.
        • November 1, 2005
        • 146
        Thanks Joe! I will need to be at .040", so I should be in good shape. I'll put a call in to my parts store and see if they can find this for me.
        Ashley
        • Ashley S.
          • November 1, 2005
          • 146
          Thanks for your help John. I've just called my parts guy to see if he can get this for me.
          Ashley
