67 Power window wiring - NCRS Discussion Boards
  • Brandon K.
    • April 1, 1997
    • 474
    Does anyone who's done a midyear (particularly 67) power window wiring job know where the relay should be located? I know it needs to be close to the fuse panel and the left kick panel where the circuit breaker is mounted. Also, does the power window breaker use the same mounting holes as the headlight circuit breaker or are they different? Finally, what is the route that the power window switch wiring takes from the dash to the console. It appears to go along the firewall and under the carpeting along on the right side of the transmission tunnel, but I wanted to make sure and avoid any pitfalls in routing the wires. Thanks again for the help!
    Brandon
    Re: 67 Power window wiring
    Brandon -
    The location/installation of the relay, circuit breaker, and harness routing down the firewall and along the passenger side of the tunnel is shown on the A31 sheet in the Assembly Manual.
    • Brandon K.
      • April 1, 1997
      • 474
      Thanks John, but I am looking at that sheet and don't see anything about the relay or breaker. Is it possible there should be two A31 sheets? I only have one.
      Brandon
        A31 Option Has Two Sheets, A1 and A2... *NM*
        • Brandon K.
          • April 1, 1997
          • 474
          Where is Relay located?
          Thanks for the info. I found sheet A1, which is very helpful and shows the location of all components, but doesnt really show where the p/w relay bolts to. Can anyone give me specifics on where the relay should be mounted?
          Thanks in advance!
          Brandon
            See View A, Sheet A1, Item 10... *NM*
