I recently performed a major restoration/replacement of the torque arm assembly and components on my '67: new torque arm, spindle bearings, seals, bushings, SS parking brake shoes, the whole 9 yards, and installed it on the passenger side. Relatively speaking, it was a piece of cake.
Now, moving over to the drivers side, there is a problem: I removed the nut on the long bolt on the forward end of the torque arm which goes through the bushing and frame and tried to remove it, but it wouldn't budge, it was frozen solid to the internal metal of the bushing shaft. I soaked the bolt in rust penetrating oil for a few days and tried to bang it out, but the space here is very limited, and it was no go, the bolt not beak loose from the bushing. Then I tried to free the bolt with a short socket and breaker bar. I managed to turn the bolt about an inch, but when I let go it returned to the same position, indicating that I was only torqueing up the rubber bushing and not busting the bolt free.
After that failed, I thought to vertically bisect the whole bushing and bolt in half with a torch, and then use a cold chisel to pop off the 2 ends off in opposite directions, which would free up the torque arm. But there are some drawbacks to this scenario, i.e., the torch would have to cut through a LOT of steel, which would ignite the rubber in the bushings. (Very Nasty). The extreme heat could damage the frame and maybe the surrounding fiberglass. I don't think this is the way to go.
My next bright idea might work: Crimp a vise grip on the bolt, resting up against the inner fender wall, then use a torch to cut the torque arm all the way through, just ahead of the spindle, and remove the entire spindle and brake assembly, leaving over a foot of torque arm, with plenty of room to work. Then I could insert a steel pole into the torque arm, acting as a lever, and break the bolt free from the bushing. This method seems to be my only recourse, but I'm not going to cut the torque arm in half until I have a shot at the board to see what your experiences were. What would you do ? Any comments would be appreciated.
