66 Corvette Tach needle bonce - NCRS Discussion Boards
  • Ken Harants
    I just had my tach rebuilt and installed a new cable. I am getting a lot of needle bonce. Is there anything I can do to stop this.
  • William C.
    • May 31, 1975
    • 6037
    Re: 66 Corvette Tach needle bonce
    Under what conditions does it bounce? At idle, it should be fairly stable, if you are reving the engine, bounce is normal to some extent.
    Bill Clupper #618
    • Gary S.
      • July 31, 1992
      • 1628
      I have read that cable bounce is typical of a poorly lubed cable. Have you tried any speedometer cable lube?
      Gary
        Add on...
        Plus, if the cable has run dry, there's a good chance the square drive end that enters the distributor has 'chewed' or 'rounded' corners now allowing it to slip as it spins. If this is so (visual verification required), it's time to pull the tach drive cable's inner cable, clean the sheath of dried/caked lubricant, purchase a cut-to fit, replacement inner cable, liberally lubricate it, and re-install it in the outer sheath to eliminate the drive cable's slipping action and consequent tach needle bounce....
        • Bill Richards
          Try loosening the cable hold in clamp, at the tach, a turn or so, this worked for me. Of course the cable needs to be lubed as well. Look for any sharp bends in your routing.... Bill
