I just replaced my transmission mount on my 67 MT conv and the new mount is slightly thicker than the one I was replacing. I called Paragon and their mounts also are the same thickness as the one I installed. Difference is about 1/4", and this makes the transmission sit higher on the car and the clearance to the tunnel insulation is very tight. Have any of you experienced this and can share your comments? My old mount wasn't really worn out, but I was replacing various potential causes of a clutch chatter I am experiencing.
When you have replaced a rear engine mount (or the trans mount I call it), did your clearance with the tunnel go to about nothing??
