K-19 smog bracket. - NCRS Discussion Boards
K-19 smog bracket.
  • Dale S.
    • November 12, 2007
    • 1224
    K-19 smog bracket.
    I have found a bracket that is supposed to be a clamp assembly 3903362. It holds the 7033546 valve assembly up off the valve cover on a 1967 327 C-2 with K19 and C-60. It mounts on a stud in the intake manifold bolt hole. My question is, does this part(3903362) have a number stamped in it? The thickness of the material is .035 thou. Appx. 1/32" and 3/4" wide. It seems thinner than the picture in the assembly manual. The shape is correct. Any help would be appreciated. Dale
  • Dale S.
    • November 12, 2007
    • 1224
    Re: K-19 smog bracket.
    Does anyone know if a 3903362 clamp assembly on a 1967 C-2 327 with K19 have a part number on it? It is the bracket that holds the diverter valve. I need to buy this if it is right. Dale
    • Mark G.
      • March 1, 2001
      • 227
