On my '67, I was fitting new front bearings, when I happened to slide one of the inner bearings on the spindle, and noticed that it is a very loose fit on the spindle shaft. Seemed that it might lead to a "spun bearing" so I am seeking the advice of the "collective". The bearing is a Timkin, so its not a piece of garbage. I already have the other side all assembled, so I decided to post the question before taking everything apart.
Is there danger here Will Robinson, or is this normal? Should the inner cage of the bearing be a tight or loose fit on the spindle? All advice welcomed.
Brandon
Brandon
