If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I am running headers (gasp...the "H" word on this forum!), what do you mean about incorrect spark plug sizes? Is there a particular casting number that will bolt in place, with necessary mounting holes (PS/alt)?
The 1969 heads used the gasketed spark plug with 13/16" wrench size whereas the 1970 and later used the taper seat plug with 5/8" wrench size. It is a visibly smaller spark plug (at the metal part). Then again, unless you really look, would you notice?
All BB heads have the necessary mounting bolt holes for the front mounted accessories, but some heads use 3/8" bolts while others use a mix of 3/8 and 7/16. You would have to look to be sure.
I had a set of the service replacement heads - either casting number 6272990 or 14096188 - still sold as part number 6260482 I think, on my 1969 L89 for about 20 years and they worked without a glitch. They used to sell for about $500 to $600 a head new from GM, but they may have been discontinued. You can easily find them at swap meets and on e-bay for a lot less than the correct casting number vintage heads.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
