Re: 63 amp meter - NCRS Discussion Boards
Re: 63 amp meter
    Re: 63 amp meter
    Jim -
    Pull the connector off the back and check each cavity for power - both should show 12V to ground; if not, pull the inboard bulkhead connector on the engine side of the fuse block and check the mating terminals for corrosion, bent prongs, etc.
