LOW VACUUM - NCRS Discussion Boards
LOW VACUUM
  • David E.
    • July 17, 2008
    • 33
    #31
    low vacuum
    I have to wonder why it is dying in the first place. I once had a problem just like yours that was caused by a clogged gas filter.
    • Albert P.
      • April 1, 2006
      • 205
      #32
      Re: low vacuum
      While it's running, if I try to "accelerate" there is no increase in rpm and I do see the squirters dumoing fuel in when I do this; all I here when I open the throttle is air being sucked in.
      • Albert P.
        • April 1, 2006
        • 205
        #33
        Re: low vacuum
        Finally got it running decently tonight; this is what I found, so far:
        I found that the centrifugal advance was not operating as ther was no lubrication between the adv plate and the main shaft; the main shaft had .040" clearance to the bottom gear; supposed to be .007"; I had to shim that. I also found that the transfer slots on the carb were overexposed, so I backed the throttle setting out to 1/2 turn past fully closed plates(edelbrock carb); I also put an echlin 1810 advance can on it; the car ran for a while with 10-14" hg; then stalled; I couldn't restart, had voltage to coil but noticed new coil was extremely hot; could this be the cause? I was so excited hearing it running decently I didn't check timing or do anything else.
        • Albert P.
          • April 1, 2006
          • 205
          #34
          Re: low vacuum
          Final results: replaced coil with generic coil from Autozone; to get timing marks to line-up, had to rotate distributor dimple 180* away from rotor tip(I have an aftermarket crane cam); right now starts well. Thanks for all the suggestions and help.
