C2 PS fluid - NCRS Discussion Boards
C2 PS fluid
  • Ralph E.
    • February 1, 2002
    • 905
    C2 PS fluid
    Just finishing up with adding power steering to my 1967 SB. Now it is time to add PS fluid. When I checked old post it was suggest to use GM 12345867($16/qt). The local Chevy Dealer suggested GM 89021184 ($4/qt). My AIM indicates 9985039 or 9985010. Which should I use?
    Also what is the capacity of PS fluid?
    Ralph #37280
    Re: C2 PS fluid
    Ralph -
    #89020661 is the P/N for the GM Power Steering Fluid (quart bottle) I bought a year or so ago. The system holds just over a quart - just enough so you need to buy two bottles.
    • Ralph E.
      • February 1, 2002
      • 905
      Re: C2 PS fluid
      Thanks John,
      You being a Michigan boy would you use the cold climate PS fluid GM 12345867 or the regular stuff GM 89020661?
      Ralph #37280
        Re: C2 PS fluid
        I use the regular stuff - don't drive it in the winter.
        • Chas Henderson #28127
          Re: C2 PS fluid
          I use the auto zone stuff and I do drive it in the winter. Work just fine!
          Chasman
          • Kevin M.
            • November 1, 2000
            • 1271
            Re: C2 PS fluid
            I've always used regular ATF to top off a PS pump, thought that's what it said on the cap.
            Kevin
            • Michael W.
              • April 1, 1997
              • 4290
              Re: C2 PS fluid
              If it says '710', you're holding it upside down.
