C-1 58 Vacuum Lines - NCRS Discussion Boards
C-1 58 Vacuum Lines
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 58 Vacuum Lines
    1958 with 230HP-Powerglide. Need help in hooking up vacuum lines. Does the distributor vacuum line go to the carb stud and where does the powerglide and windshield washers connect? Front or rear of the carb seem likely but which way? Thanks in advance.
    Re: C-1 58 Vacuum Lines
    Jerry -
    The diagrams in the Powerglide and Windshield Washer sections of Noland's book for '58 base-engine Powerglides show the distributor vacuum source as the front of the carb, the Powerglide modulator vacuum source as the hollow carb stud, and the windshield washer vacuum source as a fitting at the rear of the carb.
