What is your product preference for removing road tar from the painted body?
C3/C4 Corvette road tar removal
Re: C3/C4 Corvette road tar removal
Hi Jim,
There is a product you can get at hardware stores called "GOOF OFF" or you can go to a pharmacy and get some medical serviettes called "UNIVERSAL ADHESIVE REMOVER WIPES" which is in a 50 pc box by the company name "SMITH + NEPHEW".
The wipes are like the little restaurant towelette.
After you get the road tar off, and the area looks clean then wash it down with soap & water to get the residue off.
Hope this helps. Ken.- Top
Yes, I'm Sure Duke Wasn't Refering to.......
...lacquer thinner. That would certainly remove the tar, and a lot of other things that you probably didn't want to remove.- Top
Re: Yes, I'm Sure Duke Wasn't Refering to.......
Paint thinner is also referred to as mineral spirits. It's used to thin alkyl enamel paints and is a good, cheap general purpose petroleum solvent - works as good if not better than any "bug and tar" remover I have bought.
Duke- Top
