I've been thinking of getting the Caswell copy cad kit for some time now and after reading all the recent posts about it I have decided to get it. From those of you who have the Caswell kit, what size would you recommend I get? I'm thinking the 1.5 Gal kit would be enough seeing as the largest item I will plate is a headlight actuator. I also read someplace that the solution can be replenished with water as it evaporates...is that true?
For restoring my q-jet I was going to get some of the yellow chromate solution. To use it is all I have to do is just bead blast the housing and dip it or is it more complicated than that?
In regards to phosphating do I have to get the solution to boil or is say 200F good enough(that's all my old crock pot will do)?
Thanks again.
Greg
Thanks again.
Greg
