67' Tri-power - NCRS Discussion Boards
67' Tri-power
  • Bill Stephenson
    Re: 67' Tri-power
    --------Sure, Bill, as long as the two outer carb holes are blocked........Bill S
    • Joe R.
      • March 1, 2002
      • 1356
      Re: 67' Tri-power
      I believe that the outer two carbs are actuated by vacuum, and function just like vacuum secondaries on a 4-barrel carb. This would mean that the engine runs off the center carb at low speeds, and the outer carbs kick in only at high RPM and high load.
        Re: 67' Tri-power
        Joe -
        The engines were hot-fired at the engine plant using natural gas, supplied through an adapter that attached to the carb pad.
        • Joe R.
          • March 1, 2002
          • 1356
          #19
          Re: 67' Tri-power
          Thanks for the explanation John. That's an interesting procedure.
