TI Ignition on build sheet - NCRS Discussion Boards
  • Jeff M.
    • February 1, 1999
    • 127
    In 1971 did the build sheet call out and list the k66 option for the LT1 and LS6 cars? My thought is that it would list it as it is an option, but was considered standard on the solid lifter motors. The build sheet has a line for it, so my thought is that if the sheet was used for the line worker to build the car then they would need to have it on the sheet to know to add it. I have seen a 71 LT1 build sheet and it was not listed. I am only interested in the LS6 configuration
  • Warren F.
    • December 1, 1987
    • 1516
    Re: TI Ignition on build sheet
    Jeff,
    The Corvette Order Copy for 1971 LS-6 application does not list the K66 Magnetic Pulse Transistor Ignition set-up as this was part of the LS-6 option configuration. It also does not list the MA-6 option separately as this was also part of the LS-6 option as well.
